Hi there
I'm trying to convert my Dwg to PDF but when I do so my 1cm width border (vertically) goes missing. Does any anyone have any suggestions to resolve this?
Solved by neaton. Go to Solution.
please try to use command _PLOT to plot a layout with the corresponding layout-size, using "DWG to PDF.pc3" and use a paperformat (or create a paperformat for that PC3) which matches your needs.
- alfred -
Full bleed has a very small print border. In the Plotter Configuration Editor, Device and Document settings tab you can see the printable boundary for each size listed in the DWG to PDF.pc3. If none of these meet your needs than choose Modify Standard Paper Sizes to create your own as @Alfred.NESWADBA said.
Nancy
