AutoCAD Forum
Drop Down Menus
11 REPLIES 11
Message 1 of 12
crawfordscott
726 Views, 11 Replies
Drop Down Menus
crawfordscott
Is it possible to create a drop down menu that contains only text?
I have a sheet of data that I refer to quite often and i'm fed up having to open a document (sometimes i've got loads of documents open) or refer to a paper copy to get this info
So I'm looking for some way to create a drop down that contains this info without any commands associated with it.
I've attached an excel sheet to show what i would like to see including flyouts
Possible?
Thanks in anticipation.
Crawford
Drop Down Menus
Possible?
Crawford
11 REPLIES 11
Message 2 of 12
crawfordscott
Sorry forgot to attach example
C
C
Message 3 of 12
cadffm
in reply to: crawfordscott
cadffm
with or without a senseful command sequence doesn't matter.
Sure, your can - but it sounds you never tried it?
Are you talking about menus (MENUBAR), or ribbon only?
Menubar is perfect for this task.
Sebastian
Sebastian
Message 4 of 12
pendean
pendean
Community Legend
Community Legend
@crawfordscott help yourself, it does require some effort and a bit of studying
https://www.youtube.com/watch?v=E1n6CGemvLA
Message 5 of 12
crawfordscott
in reply to: cadffm
crawfordscott
I would prefer on the Menu bar
c
c
Message 6 of 12
cadffm
cadffm
Perfect.
Start with pendeans link.
Note: I prefer to create your own cuix file for this.
How to create a new .cuix file first:
Command: CUI
Change the tab, create a new .cuix file.
Back on the first tab:
Navigate to the partial menus in the upper left section, right click -> add your new .cuix file.
Start now to add your menus as shown in the video tutorial.
For more details and flyouts, take a look into your online help:
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-90B274D0-C750-4ADA-9D3E-2C07B157F6A3
Sebastian
Perfect.
Command: CUI
Sebastian
Message 7 of 12
crawfordscott
in reply to: cadffm
crawfordscott
Hi all those who have replied,
Thanks for the replies but I think we are at cross purposes;
I can use the CUI to make a drop down menu to which I can add commands. I've been doing this for years.
But in this instance, I don't want to add commands, I just want TEXT.
If I attempt to create a new menu its asking which commands I want to add to the menu.
Well, as I have just explained. I don't want to add commands.
I just want a list of data that can be read, nothing else.
Crawford
Crawford
Message 8 of 12
cadffm
cadffm
>>"but I think we are at cross purposes;"
No, we are all on the same track.
>>"I don't want to add commands,"
The only content of pull down menus are 1. Tools, 2. Other menus, 3. Separation lines
You ignored my previous hint: "with or without a senseful command sequence doesn't matter."
BUT: In CUI AutoCAD, Tools are called "Commands" - That's bother you
(Note: "command" like the list in lower left area of CUI dialog is a completely wrong term, AutoDESK has been using it for two decades. Better would be "Tool" and much more better "Button", but also this therms are not 100% right.)
>>"I just want TEXT"
Set up "commands" (/ Tools / Buttons) with the Text-prompt you need,
add these to your Menu. That's the way you can go.
>>"I just want a list of data that can be read, nothing else."
It doesn't matter that is called a "command", tool or button, - you can read the name and this is what you want: Just read..
Sebastian
>>"I just want TEXT"
Sebastian
Message 9 of 12
pendean
pendean
Community Legend
Community Legend
@crawfordscott wrote:
...But in this instance, I don't want to add commands, I just want TEXT....
So... where the "command" is needed, enter
^C^C
Not sure why that's not all you ever needed to do.
OR are you wanting "text" to drop into your open file?
^C^C
Message 10 of 12
crawfordscott
Thanks to all who replied.
Your input is much appreciated.
Crawford
Crawford
Message 11 of 12
crawfordscott
in reply to: cadffm
crawfordscott
Thanks for that
Crawford
Thanks for that
Crawford
Message 12 of 12
crawfordscott
in reply to: pendean
crawfordscott
Hi thare,
Thanks for the speedy reply.
Will try your recommendation.
Crawford
Hi thare,
Crawford
AutoCAD Inside the Factory
