Drawing tiny when scaled 1:100, what am i doing wrong?
Message 1 of 13
Hey guys,
Im pretty sure i have drawn my drawing at a tiny scale so when i try and plot it to 1:100 it just disappears so is there anything i can do to fix this?! I assumed i was drawing in meters so 8 meters on the site would equal an 8 when doing the line so yeah ive obviously messed up in doing this. Any help is appreciated!
Cheers guys!
Replies (12)
Message 2 of 13
Attach the drawing and we'll check it out.  Could be any number of things.
Message 3 of 13
Mark_C_123
easy way to fix this just draw a line at the correct distance and use the ''align'' comm and scale based on alignment points.
Message 4 of 13
imadHabash
it seems that it's scale issue status,I suggest to enter the digits { ( 1 - 0.1 ) and mm } see attached image.
Imad Habash
Message 5 of 13
GrantsPirate
Your model is drawn in Meters but the title block is mm so you have to change the scale of the VP by 1000.  So if 1:100 is the desired plotting scale, and MS=M and PS=mm scale would be 1 : .1
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 6 of 13
dgorsman
1 : 0.1 or 10:1 with whole numbers
Dropping the leading zero on a sub-one value is a pet peeve of mine.  Smiley Mad
Message 7 of 13
Hey guys i appreciate all of the replies! Could someone give me steps from being on the drawing page to plotting at 1:100 on an a2 piece of paper? i have attempted to change the units but the pdf i get is blank! thanks guys.
Message 8 of 13
Mark_C_123
go to your a2 paperspace sheet.
make sure you have a 1:100vp. if you dont the easiest way double click into your vp and at the bottom right hand of your screen click you scale menu ''edit drawing scale'' and create a 1:100. depending on your ''units'' it could be different mine is 1 paper space unit to .1 drawing units.
your vp will adjust.
then plot your a2 sheet. your scale will be 1:1
Hope that helps.
Message 9 of 13
does vp stand for viewpoint? and when setting up my page do i make the plot scale 1mm to 10 units? cheers
Message 10 of 13
john.vellek
Hi @Anonymous,
Did you get your answers here - you have sent me one drawing. Is that the one you need to print on A2?
John Vellek
Message 11 of 13
the drawing i sent you is indeed the drawing i need to scale but i got it wrong and it needs to be at 1:200 on a2
Message 12 of 13
john.vellek
Hi Jed – I trust you on the scales.
Here is your file with the contours inserted as a block. I then went to Layout 1 and created a Pagesetup to define papersize, plotter (OPDF), plot style, etc.
You will note the paper is set to a scale of 1:1. Then I created viewport and zoomed 1:1
John Vellek
Message 13 of 13
I really do appreciate the help mate it was very kind of you! saved me from a lot of frustration indeed. Thanks to everyone else also for the help!
