I accidently changed my scale list to XREF scale, and now I can see Xref scale only as in image 2 , how can I go back to my previous list?
Did you try uncheck Xref and uncheck Percentage in scale list.???it will go back.
watch this video https://autode.sk/2RnUmXf
Jayhar.M.j
Hi @designdistrict7 , i don'T know how you can uncheck an item you can not see,
hoping we can read about the trick later. My fast solution is to restart your Autocad,
this setting will restore to filter-xref scales then.
Try a Acad restart.
Sebastian
Use the HIDEXREFSCALES variable and set it to 1.
This way your drawing scales should return.
Scroll down that list to the bottom and uncheck Xref Scales.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
In the picture you posted where you circle the xref scales... uncheck that box and you should be good... screenshot below.
