Drawing Scale list
designdistrict7
Drawing Scale list
designdistrict7
I accidently changed my scale list to XREF scale, and now I can see Xref scale only as in image 2 , how can I go back to my previous list?
jayhar
Did you try uncheck Xref and uncheck Percentage in scale list.???it will go back.
watch this video https://autode.sk/2RnUmXf
Jayhar.M.j
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
cadffm
Hi @designdistrict7 , i don'T know how you can uncheck an item you can not see,
hoping we can read about the trick later. My fast solution is to restart your Autocad,
this setting will restore to filter-xref scales then.
Try a Acad restart.
Sebastian
Erense
Use the HIDEXREFSCALES variable and set it to 1.
This way your drawing scales should return.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
GrantsPirate
Scroll down that list to the bottom and uncheck Xref Scales.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
s.borello
In the picture you posted where you circle the xref scales... uncheck that box and you should be good... screenshot below.
s.borello
Isn't it circled in the original post?  It's circled in red.
