Do you know if there is a way to tell if an Autocad ( 2017 ) file was drawn to a certain accuracy by looking at it?
Would this be looked into through units and precision?
I know that by exploring scales drawn at you can discover what model space scale is being used to draw the whole file.
Thank you so much
- A
Solved by RobDraw. Go to Solution.
By looking at it, no. You need to set the precision as small as possible and make measurements. Precision of drawing is not reflected by any settings but rather has to do with the drawing accuracy of the author(s).
