draw parallel lines
draw parallel lines
draw parallel lines
Hi I need to draw parallel lines to create for example a staircase. By using the parallel or offset command, I can make the parallel lines but the angle of rise of the lines cannot be altered. Is there a way where this can be changed?
parallel lines need to touch the line below.parallel lines need to touch the line below.
\Pls give solution if possible.
Gazaal
cadffm
Command Copy
Sebastian
vinodkl
Hi @gazaal_c
Try using "COPY" command with array🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
imadHabash
I think that you're asking about drawing an isometric stair . click on below image and see how with ISODRAFT command you can do it. you can draw 2D isometric representations of 3D models .you can while drawing the stairs switch your direction by Ctrl+E . also you can draw a real 3d stair model by using 3d commands.
Imad Habash
imadHabash
click on below image to see how with EXTRUDE 3d command you can do a 3d solid stair . prepare your 3d polyline stair elevation in a proper angle then just extrude it .
Imad Habash
Kent1Cooper
@imadHabash wrote:
.... I think that you're asking about drawing an isometric stair . ....
I don't think so.  See the caption under the image in Message 1.  @Anonymous, can you clarify?
Kent Cooper, AIA
