Draw arrowhead without line
julia.langeT5493
Message 1 of 8
julia.langeT5493
I would like to insert only arrowheads. Is this possible? I have tried to insert an "mleader" and to either change the landing distance or set the linewidth to 0.0 mm, but this does not work. I could just draw triangles as arrowheads, but maybe there is a more elegant solution.
My aim is to draw streamlines, thus creating curved lines and add the arrowhead at some positions.
I am looking forward to your proposals!
Kind regards,
Julia
Replies (7)
Message 2 of 8
imadHabash
You can draw arrowhead with PLINE command ( Width option ) .
Command: PL PLINE
Specify start point:
Current line-width is 0.0000
Specify next point or [Arc/Halfwidth/Length/Undo/Width]: w
Specify starting width <0.0000>:
Specify ending width <0.0000>: .2
Specify next point or [Arc/Halfwidth/Length/Undo/Width]: <Ortho on>
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]:
Imad Habash
Message 3 of 8
Alfred.NESWADBA
You can create a block and then insert the block on top of the lines.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 4 of 8
julia.langeT5493
Thank you very much! The PL (PLINE) is much easier to handle than my rectangles...
Message 5 of 8
ВeekeeCZ
If you want to insert an arrowhead of dimstyle already in use, then arrowhead is automatically created block with name _Open30 or _Oblique, or DatumFilled... Look into the INSERT gallery for blocks with an underscore prefix.
Message 6 of 8
Pointdump
Julia,
"My aim is to draw streamlines"
Using >>>Measure/Divide<<< with a triangle block will do this perfectly.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 7 of 8
Alfred.NESWADBA
>> Using >>>Measure/Divide<<< with [....]
OK, following up with this I would use a linetype with automatically showing the symbols along a line ;)))
- alfred -
Alfred NESWADBA
Message 8 of 8
Kent1Cooper
@julia.langeT5493 wrote:
.... to draw streamlines, thus creating curved lines and add the arrowhead at some positions. ....
If you mean equally-spaced positions, MEASURE or DIVIDE, or better yet a linetype definition or an associative ARRAY, would do.  [The linetype and associative ARRAY approaches are better because the arrowheads will adjust their quantity and direction appropriately if you change the shape of the streamline.]
If you want to select locations that are not equally spaced, a routine could be written that would ask you to pick locations and would do the INSERTing of a Block for you, including aiming it in the direction of the streamline at that point.  [I already have something that does that with Text labels, which could be modified easily enough.]
Kent Cooper, AIA
