extruding a 3d polyline and spline combo and turning them into a solid
office6PUWT
Message 1 of 12
office6PUWT
Re the attached .dwg file I'm not sure if a spline and polyline can be combined into a single polyline that can then be extruded and turned into a soild. can anyone please show me how to turn this sketch into  120mm wide arched beam?
Replies (11)
Message 2 of 12
Alfred.NESWADBA
Not to a polyline with just one command, but you can use command _JOIN to create a new Spline-object from your existing Spline+Polyline (a bit difficult with your geometry when you then try to close the open curve).
Alternative:
You can also try with command _SPLINEDIT to convert your Spline to a polyline, then run command _JOIN to join these 2 entities, make it closed an then extrude it. As shown here:
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 12
leeminardi
  1. Close the gap where the 3D polyline meets the spline.
  2. Give the region command and select the 3dpolyline and the spline.
  3. Extrude the region to create a 3D solid.
lee.minardi
Message 4 of 12
office6PUWT
Thanks guys, really helpful.
I decided to rework the original spline and repeated the operation but was unable to create a region from my new 3d polyline using the same approach. I've checked for any gaps in the closed geometry and cannot see any. I'd be grateful if you could take a look at the this file aswell and help define what the problem is this time?
Message 5 of 12
Alfred.NESWADBA
you can use command _BOUNDARY to create a standard Polyline based on your 3D-Polyline, this new Polyline can be extruded.
- alfred -
Alfred NESWADBA
Message 6 of 12
office6PUWT
This has been a real headache, Boundary command worked for me but I had to redraw the geometry for a third time and now neither of the approaches you've shown me are working?? Could you have another look at it for me please. Attached saved as a 3d polyline from which I am unable to create a region or find any gaps.
all best
Luke
Message 7 of 12
Kent1Cooper
Does it need to be flat to make a Region?  Looking straight down the X axis which is at the right end [rotated for viewing orientation here]:
Or, in plan view:
Kent Cooper, AIA
Message 8 of 12
Alfred.NESWADBA
this time you have not drawn the objects in one plane, but to extrude a closed curve this curve has to be on one plane to get a 3D-Solid as result.
In this case you can help by setting the UCS to the plane you want to have the geometry projected to, then run command _FLATTEN and this should give you a geometry ready for running _EXTRUDE or _PRESSPULL.
- alfred -
Alfred NESWADBA
Message 9 of 12
office6PUWT
thankyou so much excellent advice.
Message 10 of 12
office6PUWT
I spoke too soon, after closer inspection the flatten tool has altered the axis of the object despite the ucs being positioned as required? see attached image
Message 11 of 12
Alfred.NESWADBA
First set the UCS to 3 of the endpoints of your contour.
Then use command _PLAN to this UCS.
Now run command _FLATTEN.
In worst case you need then to move the resulting geometry to the correct basepoint you'd like.
- alfred -
Alfred NESWADBA
Message 12 of 12
office6PUWT
excellent thankyou
