dots instead of lines
manal-abuamara
Observer Observer
manal-abuamara
Observer
Observer
need your help, I am new to autocad and when I drawing line its shows like 1 dot and I have to to zoom option to to check that line, please need your help to solve this issue.''
thank you
arturopolanco
Hi @manal-abuamara
You can apply this setting:
https://subscription.packtpub.com/book/business_&_other/9781789809152/1/ch01lvl1sec05/setting-units-...
Arturo Polanco
AEC Solutions Specialist - Civil Infrastructure
Youtube | Twitter
Pointdump
Hi Manal,
Welcome to the Autodesk Forums.
"...drawing line its shows like 1 dot and I have to to zoom option to to check that line..."
What steps are you using to draw your line? (direction and length)
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
imadHabash
It's normal .. especially when start new drawing . also it depends on your measurement values . Please .. if you need more help make another message with more details ?
Imad Habash
manal-abuamara
Observer
Observer
thank you for your reply, I am clicking on the line icon and select on the unit = meters command bar then click on the drawing aera and type for example 10, press enter then press escape.
direct the line convert to dot please see below pic, need help how to fix this issue , just to let you know, that ASUS gaming laptop with core i7 CPU , 4gb VGA card, SSD drive, 16gb ram's I believe these configurations are very good for AutoCAD 2022
[cid:5ff34b6f-ba9b-4ddb-9d76-811c38ef8778]
thank you
Kent1Cooper
@manal-abuamara wrote:
...I am clicking on the line icon and select on the unit = meters command bar then click on the drawing aera and type for example 10, press enter then press escape.
direct the line convert to dot please see below pic....
The picture didn't attach normally.
Is it really a "dot"?  If you select it, what does Properties say about its length?  Could it just be that you are Zoomed out so far that its length is not apparent on-screen?
Kent Cooper, AIA
