Display mesh line
Display mesh line
LenKwaiKeong8457
Message 1 of 10
Display mesh line
LenKwaiKeong8457
Hi, In AutoCAD layout got anybody know how to hide the mesh line. Its mean that make it look not so messy. Any solutions about it?
*DISPSILH to 1 - this is not work for mesh line, Its just for 3D object solid.
Any other solutions?
Thanks !
Replies (9)
Message 2 of 10
imadHabash
Can we have one chair (dwg) here for testing?
Imad Habash
Message 3 of 10
Brock_Olly
From ReMark on Cadtutor:
Some settings that affect 3D output:
DISPSILH – Display Sihouette
This setting affects the results of the Hide command. A setting of 0 displays tessellation lines. A setting of 1 suppresses tessellation lines.
FACETRES – Rendered Object Smoothness
This setting affects both rendering and hide results. The default setting is 0.5. The max setting is 10. A lower setting results in a quicker render time but rounded edges will appear as a series of straight segments. A higher setting results in a longer render time but rounded edges will appear much smoother.
ISOLINES – Contour lines per surface
This setting affects the wireframe view but not the Hide or Render commands. Settings can range from 0 to 2047. The default setting is 4.
SPLINESEGS – Segments in a Polyline Curve
This setting controls the number of segments in a polyline curve. The settings range from 0 to 32767 with the default being 8. The higher the setting the smoother the appearance is of a rendered curve.
Message 4 of 10
LenKwaiKeong8457
Hi, Please refer attached file.
Message 5 of 10
LenKwaiKeong8457
Thank you for your explanation, but it doesn't work for me.
Message 6 of 10
j.palmeL29YX
Edit the chair block EDWG0EC5894E052A491AA3913155A170C450 (bedit or refedit command) and explode its subblock 72bnx_ports366A8593A1AAA48E09358BD6C2BF7D290 (the mesh). Save the edited block and choose a suitable Visual Style (e.g. conceptual).
Result attached.
BTW: Some of the furniture is placed incorrectly. See attached video.
Jürgen Palme
Message 7 of 10
LenKwaiKeong8457
Hi, I felt very appreciate on your clear explanation & info. Actually what I need is when I print out or convert to PDF, the mesh line disappear.
Please refer to the attached file.
Message 8 of 10
j.palmeL29YX
Given such an object without any edges, what lines would you want to see to describe and visualize the geometry? Pick up a pen and try it. AutoCAD is beyond its capabilities.
I think you will have to model your own simplified chair (3D model).
Jürgen Palme
Message 9 of 10
LenKwaiKeong8457
Hi, Please refer to the file, this is what I want.
I think AutoCAD cannot, is there any other solution?
Message 10 of 10
LenKwaiKeong8457
Very clean, without too many lines.
