Sweep command + twist = problem
Mardaji
Message 1 of 11
Mardaji
Hi, I'm an Autocad 2023 user and I'm trying to use the sweep command associated with the rotate by a path option, (line) but instead of receiving the field to enter the profile rotation angle I receive the following "Sweep  Enter group name" message.
But  I didn't create any group and if I create it and try to do the operation it doesn't work.
The other Sweep options work correctly.
How do I solve this problem?
At
Vagner
Replies (10)
Message 2 of 11
imadHabash
Would you please share the AutoCAD file for testing?
Imad Habash
Message 3 of 11
VincentSheehan
How about this?
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Message 4 of 11
Mardaji
Of course!!!
Message 5 of 11
Mardaji
It doesn't work either
Message 6 of 11
imadHabash
Thanks for the file....
Click on below image to see that it's normal, AutoCAD didn't display any messages.
Imad Habash
Message 7 of 11
Brock_Olly
It works well on my end, you are selecting 'G' for Girer, which is T for Twist I think?
After pressing T, it asks to define an angle, and then when you type 180 for example it will work for me.
Perhaps there's an issue with the translation? After pressing G you should not get the 'group' message?
If you have the english version installed try giving it a go there?
Message 8 of 11
Mardaji
The suggested solution which worked, was to write the entire name of the twist option instead of abbreviating it or clicking on T
Message 9 of 11
Brock_Olly
So probably a bug with the language pack then
Message 10 of 11
Mardaji
Hi, the solution was to write GIRAR and not click or abbreviate G
Message 11 of 11
Mardaji
Perhaps yes,
thanks
Vagner Mardaji
