AutoCAD Forum
Display colour inverse CAD2017
4 REPLIES 4
394 Views, 4 Replies
ABOVE: This the jpg file I have to import to CAD 2017,
BELOW: this is how the jpg file been displayed on CAD 2017.  how can I fix it? The colour of images shows correctly on my extended monitors. but not on the main screen.
4 REPLIES 4
imadHabash
HI,
would you try to disable hardware acceleration from 3DCONFIG command. then try to insert it again.
Imad Habash
elshawadfy
Hi @Anonymous!
* Follow @imadHabash advice first & see what happens..
     1- First of all, that's not the negative, it looks like one color is filtered away or so (Cyan maybe)..
     2- Attaching is most likely to work better than inserting as an OLE (Copying and pasting for instance) so you may use ImageAttach instead if possible.
     3- If you're using an image format that retains Alpha channels (Tiff, Png...), get rid of them (Alpha channels or masks)..
     4- Make sure the Photo editing application you're exporting from is exporting all color channels (without alpha or masks)
     5- In Autocad, disable transparency in the image (if applicable) from image properties, make sure the layer also doesn't have any, and remeove XRef fading as precaution..
in reply to: imadHabash
Thanks for your suggestion. Problem is now solved.
in reply to: elshawadfy
thanks for your advice. I will try this next time, if the problem still occurred.
AutoCAD Inside the Factory
