ABOVE: This the jpg file I have to import to CAD 2017,
BELOW: this is how the jpg file been displayed on CAD 2017. how can I fix it? The colour of images shows correctly on my extended monitors. but not on the main screen.
Solved by imadHabash. Go to Solution.
HI,
would you try to disable hardware acceleration from 3DCONFIG command. then try to insert it again.
Imad Habash
Hi @Anonymous!
* Follow @imadHabash advice first & see what happens..
1- First of all, that's not the negative, it looks like one color is filtered away or so (Cyan maybe)..
2- Attaching is most likely to work better than inserting as an OLE (Copying and pasting for instance) so you may use ImageAttach instead if possible.
3- If you're using an image format that retains Alpha channels (Tiff, Png...), get rid of them (Alpha channels or masks)..
4- Make sure the Photo editing application you're exporting from is exporting all color channels (without alpha or masks)
5- In Autocad, disable transparency in the image (if applicable) from image properties, make sure the layer also doesn't have any, and remeove XRef fading as precaution..
thanks for your advice. I will try this next time, if the problem still occurred.
