Disappearing text
Disappearing text
rsheppa8
Observer Observer
Disappearing text
rsheppa8
Observer
Observer
When I create a text box and type in it or use dimensions, the text disappears, however, if I hover my mouse over the text it shows up. I know I’m doing this in layers that are not hidden, I have tried using several different fonts so I don’t think the issue is them not being downloaded, I also know that the font size is okay because I can see it when my mouse is on it, I have also made sure that ANNOALLVISIBLE is set to 1. Hoping someone can think of what might be the issue here
paullimapa
Is this happening on a new install of AutoCAD?
Perhaps try setting GFXDX12 to 0, close & restart AutoCAD to see if that helps.
Paul Li
IT Specialist
@The Office
rsheppa8
Observer
Observer
This worked, thank you!
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
hui.ping.qiu
Hi @rsheppa8, glad to hear that the problem has been fixed!
Could you share a sample drawing that we can investigate more for this issue? Thanks!
BTW, which AutoCAD version are you using?
