AutoCAD Forum
Disabling autosave permanently
11 REPLIES 11
Message 1 of 12
5833 Views, 11 Replies
Autosaving is highly disruptive to our work as saving takes a long time. Accordingly we've tried a few things:
- Increasing the autosave interval
- Disabling automatic save
- Disabling "create backup copy with each save"
These steps resolve the issue temporarily but when the drawing is reopened autosave is re-enabled and the interval is reset to 15 minutes. Is there any way to permanently disable autosave?
Thanks.
11 REPLIES 11
Message 2 of 12
Alfred.NESWADBA
If you uncheck the checkbox in the OPTIONS dialog (shown in the screenshot), then it should not reset itself to enabled.
If it activates itself after AutoCAD is restarted or after you logged out and back in to your Windows, then your AutoCAD profile is not saved in the registry. This is more then an issue of permissions, not of AutoCAD.
OR ... someone added a tool AutoCAD (could be ACADDOC.LSP, ACAD.LSP and a lot more) which set the autosave to active, then you need to speak with the guy who implemented that.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 12
in reply to: Alfred.NESWADBA
Hi Alfred,
Thanks for your response. My guess it it's the registry issue. How do I go about solving that?
Message 4 of 12
Alfred.NESWADBA
First you need to identify when the setting resets.
First start AutoCAD, then in OPTIONS disable the checkbox for autosave and now
  • create a new document ... check the setting in OPTIONS
  • close AutoCAD, reopen AutoCAD, create a new document, check the setting
  • logout from Windows, login, start AutoCAD, new document, check setting
  • restart workstation, all again
Which of these steps hold the autosave setting disabled, which of these steps activate the setting
- alfred -
Alfred NESWADBA
Message 5 of 12
After saving a drawing with autosave disabled, closing AutoCAD, then reopening the file, the setting is reverted to enabled with 15 minute intervals.
The setting also reverts when a new/other drawing is opened in the same AutoCAD window.
Message 6 of 12
Alfred.NESWADBA
Well, 2 possibilities, Registry or added tool like ACAD.LSP
In case of registry you need your IT (network admin)
In case of tool you need to ask the guy who is responsible for AutoCAD profiles. It can be a line in file ACAD.LSP, it could also be an app loaded into AutoCAD.
- alfred -
Alfred NESWADBA
Message 7 of 12
Ended up being a LISP command enforcing autosave. Thanks for the input
Message 8 of 12
RobDraw
Thanks.
Do you know why it takes so long to save your drawings? That's usually an indication that there is a problem. Disabling autosave is only treating the symptom, not solving the actual problem.
Rob
Message 9 of 12
in reply to: RobDraw
Agree with your statement. The short answer is no, we do not know what causes long save times. It seems to be related to xrefs.
Message 10 of 12
allanthebruce
Any chance you can tell mw what the lisp looks like or where its placed?
we are having this issue and need to find but have alot of them.... thanks
Allan
Message 11 of 12
cadffm
in reply to: allanthebruce
Did you start Acad in /safemode and the issue gone in this safemode session?
Sebastian
Message 12 of 12
allanthebruce
I found this lisp about 30m ago in the folder of lisp's and removed it, it was the guilty one:
Thanks for the message. (soooooo much lagging now gone!!!)
(vl-load-com)
(if (null *autosave-reactor*)
(setq *autosave-reactor*
(vlr-command-reactor "autosave"
(:vlr-commandended . autosave)
(:vlr-commandcancelled . autosave)
(:vlr-commandfailed . autosave)
(setq *autosave-acdoc* (vla-get-activedocument (vlax-get-acad-object))
*autosave-count* 0
(defun autosave ( obj arg )
(if (and (zerop (rem (setq *autosave-count* (1+ *autosave-count*)) 20))
(= 1 (getvar 'dwgtitled))
(vla-save *autosave-acdoc*)
(princ)
(princ)
Forma Design Contest
AutoCAD Beta
