AutoCAD Forum
Disable auto-login for ProjectWise plugin
2 REPLIES 2
2775 Views, 2 Replies
How can I disable the automatic login option for ProjectWise plugin inside AutoCADD? I couldn't find a solution online.
2 REPLIES 2
dgorsman
Check the registry for the demand-load key.  It will point to the Projectwise DLL.  Change the load flag to 0 to disable auto-loading.  You might also select a value to load on command invocation later in the session.
in reply to: dgorsman
I'll give this a try. In what folders is the demand-load key located inside the registry?
Forma Design Contest
