DIMSTYLE Center Marks not shown
SEC_MECH
Message 1 of 8
SEC_MECH
I cannot get center marks to show when I create a radius dimension.
1) DIMSTYLE is not available in the ribbon under Annotate\Dimension. I have to use the command DIMSTYLE to open the Dimension Style Manager.
I have seen clips of others ribbons. Mine looks nothing like theirs. I am using AutoCAD Mech 2019.
The attached image shows my ribbon is missing this command.
I cannot even add DIMSTYLE to my palette as it is not an available palette command.
2) Even though I set center marks to "Line" with 4 units I still do not get a center mark.
The attached image shows what I get on the left compared to what I am trying to achieve on the right.
3) If I create the radius dimension and then go to its properties it says that Center mark is set to line of 4 units but there is no center mark.
Any help will be greatly appreciated.
Thanks.
Replies (7)
Message 2 of 8
jayhar
Command: _dimcenter
Select arc or circle:
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 3 of 8
cadffm
I don't know what @jayhar talked about? But when you want to get this center mark:
you have to set DIMTOFL off
 and place the dimtext outside of the circle/arc.
Is it working now?
You will find the dimtofl setting for your dimstyle here:
Edit your DIMSTYLE <your dimstyle> EDIT, Tab "FIT", lower right corner -> Fine tuning [Draw a line between ext lines]
And one hint more: Your Picture shows a mistake.
1. You talk about dimradius
2. But you show the setting of the main dimstyle "My ISO-25"
The right position to edit or to show the setting for us is the radius substyle "My ISO-25:Radial",
this is the style which acad will use for a new radius dimension..
Sebastian
Message 4 of 8
SEC_MECH
Thank you. That was exactly the explanation that I needed. I didn't show the Radial dimension style because it seemed to be inheriting any changes that I made to the parent dimstyle "My ISO-25".
Message 5 of 8
SEC_MECH
Thanks jayhar that would work too but is a two step process - placing the center mark separately from the radius dimension.
Message 6 of 8
shofland
This solution did not work for me.  I still cannot get a centermark to display for my dimensions.  Interesting thing is that my students -- doing the same drawing with the same version (CAD2022) on the same hardware -- do display centermarks.  Any other suggestions?
Message 7 of 8
pendean
Community Legend
Community Legend
@shofland show your work: share your DWG file here, add notes/point to the area that "it dos not work"and explain your final intent in it.
Message 8 of 8
alec_sandovalQ355X
You man have to turn "Dim line forced" to off.
