- Mute
- Permalink
- Report
I cannot get center marks to show when I create a radius dimension.
1) DIMSTYLE is not available in the ribbon under Annotate\Dimension. I have to use the command DIMSTYLE to open the Dimension Style Manager.
I have seen clips of others ribbons. Mine looks nothing like theirs. I am using AutoCAD Mech 2019.
The attached image shows my ribbon is missing this command.
I cannot even add DIMSTYLE to my palette as it is not an available palette command.
2) Even though I set center marks to "Line" with 4 units I still do not get a center mark.
The attached image shows what I get on the left compared to what I am trying to achieve on the right.
3) If I create the radius dimension and then go to its properties it says that Center mark is set to line of 4 units but there is no center mark.
Any help will be greatly appreciated.
Thanks.
