In some drawings the autocad command "dimspace" works on vertically dimensions fine but not on horizontal dimensions. Anyone have this happen and know a fix.
Solved by imadHabash. Go to Solution.
maybe it's a UCS problem . would you attache here a CAD dwg sample that represent your issue ?
Imad Habash
Here is one of the drawings, maybe it's a UCS problem, this is something I had not considered....what do you think
It's a UCS problem ... you need to check your ucs orientation .
Imad Habash
