The drawings I always work with are scaled up by 1000. Currently I have to select every dimension to override each text individually. Is there a routine or a way to divide all of the text by 1000 to the nearest decimal place?
Thank you
Solved by tramber. Go to Solution.
Open up the DIMSTYLE on your current styleand modify it with a factor :
(in your own language 😉)
