Dimensions wrong in paper space
Message 1 of 13
I have set all the settings up correctly for dimensioning in paper space but when I do the dimension it is showing as 120 for example. But should be 12025mm which is what it measures at. Can anyone help me? IMG_0253.JPG
Replies (12)
Message 2 of 13
Alfred.NESWADBA
welcome @Anonymous!
In case the incorrect dimension value is shown for dimensions created with object-snap (to existing model-space objects) ... please upload the dwg file with your dimension object marked which shows the incorrect value so we can look into your settings.
If everything would be set correctly then AutoCAD would show the correct value. 😉
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 13
I have attached the dwg file. I have drawn one dimension, however after experimenting it is all that are wrong.
Message 4 of 13
Alfred.NESWADBA
edit your dimension style to be not annotative, set it to dimscale = 1 and you'll get the correct value displayed.
Making objects annotative only makes sense for model-space objects, which are then displayed in multiple viewports with different scales.
- alfred -
Alfred NESWADBA
Message 5 of 13
Thank you for helping, I have just changed it and unticked the annotative box and they're still appearing too small? 418 instead of 41825 or something similar.
Jade
Message 6 of 13
Alfred.NESWADBA
And you have created a new dimension? (the old one already has the annotative flag)
- alfred -
Alfred NESWADBA
Message 7 of 13
Yes I drew a new dimension. It says in the properties annotative no as well.
Jade
Message 8 of 13
Alfred.NESWADBA
have you used object snaps to create the dimension (in your first drawing you had not, the right dim-point was created in empty space).
- alfred -
Alfred NESWADBA
Message 9 of 13
Yes I realised that, I tried again snapping them, even on a different measurement and the same thing is still occurring.
Jade
Message 10 of 13
Alfred.NESWADBA
Please upload the last drawing with the new dimension (dimension style not annotative).
- alfred -
Alfred NESWADBA
Message 11 of 13
Thank you, here it is with a few dimensions. All should be essentially times by 100.
Message 12 of 13
Alfred.NESWADBA
I don't know what you select (which object snaps are activate when you create this dimension)
When I turn on the ANNOMONITOR I see that this dimension is not anchored to a geometry.
Using command _DIMREASSOCIATE and show 2 end-points resolves the dim-value.
- alfred -
Alfred NESWADBA
Message 13 of 13
Thank you so much! this has worked
