AutoCAD Forum
Dimensions and texts is locking
4 REPLIES 4
1863 Views, 4 Replies
Hello.
I have a problem,
My autocad is locking only  on the texts.
When I select some text or dimension, it takes a long time to edit,
I can only edit some text when I give aedit or move comand before selecting the item,
but when I want to change the number of the dimension, for example,
I do not have any commands to press before to not lock.   I have tried several solutions, but I still have not found anything to solve.
Hello.
I have a problem,
4 REPLIES 4
pendean
pendean
Community Legend
Community Legend
Is this a new problem? Or a new installation of AutoCAD or Widnows?
Is the problem limited to one file, or is this a problem in all files?
What is your AutoCAD version?
Windows version?
How many TTF fonts do you have in WIndows, and how many SHX fonts do you have in AutoCAD's Fonts folder? And by chance did you just add many more to either folder?
Windows version?
in reply to: pendean
This is a problem in all files. I changed the version to autocad 2018, but
the problem is not resolved.
My fonts is ok, i didn't add any fonts
pendean
pendean
Community Legend
Community Legend
Turn off RIBBONCONTEXTSELECT and see if that helps.
If you can, also post a DWG file with the problem, let's all try it.
michaelTVTHU
michaelTVTHU
Community Visitor
Community Visitor
 RIBBONSELECTMODE changed to "0" and it worked.
AutoCAD Inside the Factory
