AutoCAD Forum
dimensioning
4 REPLIES 4
307 Views, 4 Replies
dimensioning
im trying to dimension an angular line, lets say at 45 degrees
How do i get the dimension line to appear parallel to the line sized rather than horizontal or vertical as is the default
frustrated!!!
4 REPLIES 4
steven-g
Look for the "aligned dimension" rather than "linear dimension"
in reply to: steven-g
many thanks
i found it just after i posted.....typical
imadHabash
i suggest to look from DDIM command and Modify your current dimension style . you may try Text Alignment or Text placement (see below image )
Imad Habash
Kent1Cooper
DIMALIGNED is the answer to your specific question, but also investigate DIMROTATED for related circumstances.
Kent Cooper, AIA
AutoCAD Inside the Factory
