Dimension snapping into outer space
lhenderson9L642
lhenderson9L642
I draw an object in Top View. I proceed to dimension it....I snap and shift+right click to ensure I am selecting the endpoint of my object on either side. Once finished I turn my object with 3DO (3dOrbit) command and it shows my dimension displaced into outer space from where my object is.  When I select my dimension the blue grips show up as being connected to my object but my actual dimension is a galaxy away! Lol What am I doing wrong? Also, is there anyway to turn off the ZFilter to help with this?
cadffm
>>"Lol What am I doing wrong?"
You draw in the current ucs, it seams your pickpoints are not in this plane..
Command: UCS
(but the dimension points are always created on the picked points, thats important specially for assoc. dimension)
>>"Also, is there anyway to turn off the ZFilter to help with this?"
I am not sure what you mean, the only "Z-filter" is OSNAPZ, read more about in the help[F1]
(and pointfilter are available too, but this isn't a "running" feature:)
Sebastian
lhenderson9L642
Yes, I always type in the UCS command and ensure it is set to World.  I assume this is standard/default? You mention "You draw in the current ucs, it seams your pickpoints are not in this plane.." then how do I ensure my pickpoints are in the same plane?
cadffm
It is default and for 2D drawings
it's a kind of standard, yes.
>>it You mention "You draw in the current ucs, it seams your pickpoints are not in this plane.."
My opinion" This is the wrong question".
(The answer would be, use UCS command to set the plane you want)
UCS[F1]
The question is what you have, what you want (and why).
This is a good time for me to leave the thread,
hopeful another helper jumps in to teach to.
Sorry
The best way to get help: Upload your DWG, so we can see what you have.
Sebastian
pendean
Community Legend
Community Legend
UCS and PLAN commands both need to be set to WORLD: see if that solves your issue.
After that you probably ought to post your DWG file so we can look into your file for ourselves to spot any issues.
