- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there
I am having a problem on my drawing, I have 5 viewports, 4 are set to 'As displayed' and one is set to 'Legacy Hidden'
In the 4 viewports I have used different dim styles and layers specific to the scale set in the viewport (i.e.dimensions to be shown in the viewport with a scale of 1:5 will be in layer dim 1 to 5 and the dim style will be set accordingly)
Everything appears to be correct on screen, but when the drawing is plotted the dimension lines in the Legacy hidden VP appears to be a lot thicker than what was shown on screen.
By comparing the differences I am certain that this only affects the VP which is set to Legacy Hidden.
I have tried changing this to 3D hidden or Hidden but this means I don't get crips lines as Legacy Hidden
However, in order to display my 3D model correctly, I have to use Legacy Hidden for that particular VP.
I have tried setting the following:
<Plot object lineweight - Yes>
<Scale lineweight> No difference when selected or not
<Plot options> Tried different settings but don't seem to work
The dimensions in both views are set to the same scale, dim style and the same layer, but the one on the left is in legacy hidden and the one on the right (SECTION A - A) is in As displayed, which shows correctly when plotted.
Are there any other options that I can try?
