Is there a way to move a rectangular extruded hole within a solid
Karol-Or
Message 1 of 8
Karol-Or
In Inventor every action has a name in a tree and it can be deleted or moved, i think.
Is there a way to move a hole in Acad 2013?
I try to select each face of the hole separately while pressing Ctrl, but when i rotate the model the selection cancels
Replies (7)
Message 2 of 8
GrantsPirate
I am able to Ctrl+pick a side surface and without rotating, but with selectioncycling on, and pick the other side, hold Shift down, pick the two grips needed and drag the opening to a new location.  I am also able to Ctrl+pick a side, use '3Dorbit or using the Shift+middle mouse button, to pick the other side, hold shift while picking the two grips needed and drag it to a new location.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 3 of 8
SOLIDEDIT FACE MOVE
Message 4 of 8
Karol-Or
When i was outside with the laptop i could select any overlapping face by using Ctr and selectioncycling on. the wisual style was wireframe.
i got home, opened the same drawing and i can't select overlapping faces anymore. only when i pause on an edge the selection cycling appears
Message 5 of 8
Karol-Or
Something happened and when i hover on overlapping faces, and press Ctrl-nothing happens, the list of faces doesn't appear.
selectioncycling=2
The Selection Filters is set to none.
I could select overlapping faces a day ago, but why not now?
Also, when i set the filter to faces only, the list appears without pressing Ctrl but as i pass, item after item, in the list-the matching face doesn't highlight. the whole solid is highlighted at the beginning and it stays so as i scroll down through the list of faces.
Message 6 of 8
GrantsPirate
It is 100% reliable to 3Dorbit to pick the other face.  I too had trouble picking a face behind another face, picking over and over in different spots would finally get me there but why not just 3Dorbit and get it done?
GrantsPirate
EXPERT ELITE MEMBER
Message 7 of 8
With SOLIDEDIT, pick the front face, then pick in the same spot for the face below, then R for remove and pick the front face again.
Message 8 of 8
Karol-Or
It doesn't pick ANY face at all! it did, yesterday, i was out with the laptop.
Came home, copied the file to the hard drive on my network, opened it, and whatever i do now: set and cancel filters-nothing.
When i set object filters to Faces-the list appears but only the whole body is highlighted, no matter which face i select.
I will save as and clean the drawing and send it later.
