Dimension Grip Edits Not Sticking When Save, Close, & Re-Open
saraj3DFU9
saraj3DFU9
Community Visitor
Community Visitor
If I use the grip on the dimension to "Move" or "Stretch" the text to position itself somewhere other than the default location, it resets itself when I exit and re-open the drawing.  This causes us to waste a bunch of time making the drawing look nice, only for it to all go back to how it was once we close the drawing and return to it at a later time.  Is
there any way to make these stick?  Below are examples of the drawing after I moved/stretched the grips on the text and then what it looked like after saving, closing, and re-opening the drawing.  Everything jumped back to where it started before I moved/stretched it.
Valentin_CAD
@saraj3DFU9 ,
Welcome to the AutoCAD forum!
Consider posting the drawing.
In the meantime look at these links:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
