dimension disappearance in xref
i draw a normal drawing and i placed dimensions but when i xref this file to another file the dimensions just disappear.
in the same time when i open the original file i find the dimensions in their places correctly.
how do i make the dimensions appear in the xref file?
ennujozlagam
have you try regenall command or change value  ANNOALLVISIBLE and see if helps. thanks
vinodkl
Open the external reference manager command "ER" and then try reloading all the xref.
If this doesn't work then check if the dimension is annotative(select the dimension and see properties). If yes then try to match the annotation of xref and the drawing into which its been xrefed.
Still not working, then attach the drawing along with xref so that we can test what is going wrong.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
ANNOALLVISIBLE  worked, thanks a lot
cadffm
If this works, you should learn about annotation feature!
The problem is that your annotation dimensions are not set up to you current annotation scale.
Sebastian
snicolasora3rd
Community Visitor
Community Visitor
Try to set the value of ANNOALLVISIBLE to 1
