Dimension color doesn't update
3wood
Advisor Advisor
3wood
I have a dimension which color is yellow but actually shows cyan.
It doesn't change after REGEN or REGENALL. Not even after using entupd.
I found the only way to get it right is to delete it first, then use OOPS to get it back.
How can I get it show the correct color without using Delete-Oops method?
I attached the file here for your testing. Thank you.
WeTanks
Please take a look at this recording.
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
a_meteni
imadHabash
Hi 3wood ,
Reset text position will fix the issue also.
Imad Habash
3wood
@imadHabash @WeTanks @a_meteni
Thank you for great ideas.
I attached an updated drawing, the dimension color is in ByLayer.
Other than Delete-Oops and physically changing some of the dimension properties such as dimension color and text position, or match properties (in the new example drawing, there is no 'good example' object as the source), is there any other way to update the dimension display? It seems a bug to me. Why it doesn't update after REGEN or even upon opening the drawing?
imadHabash
Reset text position fix the issue!!
Imad Habash
WeTanks
We.Tanks
図面一括印刷
