welcome @forums.autodesk.com!
The principle steps are:
I know the answer is a very global one, but at least like your question is it too. Let us know if you have some specific questions about the procedure.
- alfred -
>> Can you please send me a tutorial(video)
Have you tried what I described?
Questions in a forum are always welcome, but a forum is not a replacement for a class/training.
And btw.: making a video for 2 commands which are described well in the help of AutoCAD uses more time for me than you need to read the help and try to use the commands as described in the help.
You might describe what you tried and why you think it's not working then we can help. But please understand that I also need to keep my time under control.
- alfred -
I put this together from another post but the parts are basicaly the same.
Bring in your image as @Alfred.NESWADBA suggested and make sure your image fits your coordinate and then trace it using CAD. The below example used the EXTERNAREFRENCE dialog to bring in the image but its not the only way to import your source.
If your source happens to be a vector PDF i would open it in CAD 2017 and it will import all the geometry for you.
CADnoob
