Difference in Plotting on different computers
Hi there,
We're having a problem with plotting the same drawing but from two different computer coming of differently.
Plotting from Computer 1 gives the correct margins as the drawing is set up. Computer 2 changes the margins so that the whole of the drawing is further down on the page.
I have tried copying over the .pc3 file from computer 1 to 2. I have also checked that all obvious plotting settings are the same.
Could someone tell me where i should be looking to compare the settings?
Caroline
john.vellek
Hi @Anonymous,
When you copied the PC3 file did you also get the PMP file? When you make changes to filter paper sizes or adjust margins the changes are save in those files.
John Vellek
john.vellek
HI @Anonymous,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post solves your issue or answers your question.
John Vellek
Hi John,
I didnt try your way in the end (I'll try it if it happens again). I managed to sort it out just by setting the margins to exactly the same as computer 1 on the second computer and that seemed to fix it.
Thanks for the replies anyway.
Caroline
john.vellek
Hi @Anonymous,
Yes, that is the information stored in the PMP file. I'm glad that you got it to work.
John Vellek
