Did SOLIDEDIT commands change from AutoCAD 2014 to 2017?
Dear AutoCAD Friends,
Recently updated to AutoCAD 2017 from 2014.
Have the SOLIDEDIT commands changed?  Do I have a toggle (an option) switched incorrectly?
Seems like the new 2017 SOLIDEDIT commands are much more monotonous — difficult to work with than 2014.  I am having to take extra steps when editing — such as manually repositioning the UCS — use a plane for slicing — etc.
Any suggestions would be helpful.
Thanks all,
Rocky
@Anonymous for clarity VStudley edited the original subject: AUTOCAD 2017 SOLIDEDIT COMMANDS
Victoria.Studley
Hi @Anonymous,
There are a few things that have changed between AutoCAD 2014 and AutoCAD 2017, which might affect the way you create, edit, and navigate 3D models.
Take a look at the changes in the preview guides via the following links (I'll put the page numbers for 3D enhancements in parentheses for clarity):
You might also find these solid editing webinars helpful, which cover the commands and their functionality in both AutoCAD 2016 and AutoCAD 2017:
If you're having specific trouble with one or more of the SOLIDEDIT commands, could you record a quick Screencast to show us exactly what's going wrong for you?
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Victoria.Studley
Hi @Anonymous,
I'm just checking in again to see if you need more help with this. Did the suggestions and resources I provided yesterday help you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
dgorsman
I haven't found much that is different e.g. I've always had to specify a plane for SLICE, whether it's by 3 points or aligned with an axis.  Perhaps you could give a more concrete example?
It's possible you've made changes in the 2014 release and not applied them to the 2017 release.  Maybe start with the setting for dynamic UCS and 3D object snaps.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Dear AutoCAD colleagues,
I think that I may have just learned that one reply covers all.
Sorry for the duplicated replies.
Thanks again,
Rocky
My apologies for not responding previously — I have been slammed here at work.
I greatly appreciate the solutions / suggestions provided; however, I still have questions.
I plan on uploading a screencast when time permits — offering examples of the SOLIDEDIT issues that I am experiencing.
Many thanks to you all,
Rocky
Two examples of changes in the SOLIDEDIT commands.
I hope this Screencast works — my first try.
