xref
xref
Message 1 of 13
xref
my xref is attached to my drawing yet I can't see it on my screen
Replies (12)
Message 2 of 13
Alfred.NESWADBA
welcome @Anonymous!
Please open XRef-manager and look to the status of the XRef, also right click the line with the XRef and try "Reload" ... does that help?
BTW: which version and service-pack of AutoCAD do you have?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 13
imadHabash
HI,
>> my xref is attached to my drawing yet I can't see it on my screen <<
you may need to check your layer status . if you close your drawing and reopen it again is the same problem happened ? does your xref loaded well in your drawing ? have you check the scale and block units in the attachment dialog through attachment procedure ?
Imad Habash
Message 4 of 13
it's all there AutoCad 2018
Message 5 of 13
it loads fine I just cant see it if I scroll using the pan command I see it but once I close out of pan its not shown.
Message 6 of 13
Alfred.NESWADBA
Excuse me, that answers 1 of 4 questions ...
These are open:
  • which service pack
  • which status does the referenced file have in the XRef manager
  • what happens when you reload it
- alfred -
Alfred NESWADBA
Message 7 of 13
imadHabash
>>  I see it but once I close out of pan its not shown. <<
from 3DCONFIG command try to disable your hardware acceleration and see if any changes .
Imad Habash
Message 8 of 13
Alfred.NESWADBA
Please try to turn off hardware acceleration (command _GRAPHICSCONFIG), can you now see the XRef?
It might also help if you change the visual style to "2D Wireframe".
- alfred -
Alfred NESWADBA
Message 9 of 13
that worked thank you very much
Message 10 of 13
imadHabash
>> that worked thank you very much <<
great ... glad to hear that . 🙂
Imad Habash
Message 11 of 13
Alfred.NESWADBA
if disabling hardware acceleration worked you should think about graphic card driver update, because XRef-disappearing should not happen.
- alfred -
Alfred NESWADBA
Message 12 of 13
imadHabash
>> ... you should think about graphic card driver update, because XRef-disappearing should not happen. <<
agreed .
Imad Habash
Message 13 of 13
looking into that now.
Thank you
