dialog box missing
dialog box missing
Message 1 of 32
dialog box missing
when using certain commands ie insert or dimstyle my dialob boxes do not display. instead it gives me prompts. i have changed the system variables to (1) and nothing changed. any suggestions? i am using autoCAD 2010
Accepted solutions (3)
Replies (31)
Message 2 of 32
imadHabash
>> instead it gives me prompts <<
you may need to change FILEDIA = 1 .
>> i have changed the system variables to (1) and nothing changed.  <<
what system variables !!!
Imad Habash
Message 3 of 32
i tried that and it did not fix it.
Message 4 of 32
imadHabash
please show us a screenshot describe exactly your issue .
Imad Habash
Message 5 of 32
TheCADnoob
how are you initiating the commands? if using the command line what exactly are you typing?
CADnoob
Message 6 of 32
the system variables i changed are
attdia
cmddia
filedia
Message 7 of 32
i normally use the icon to start the command. sometimes i will type it into the command line.
Message 8 of 32
imadHabash
close your AutoCAD and reset AutoCAD to default settings . >> Click <<
Imad Habash
Message 9 of 32
john.vellek
Hi @Anonymous,
Have you checked the CMDDIA variable to see if it is turned on?
John Vellek
Message 10 of 32
-FDC-
ATTDIA and ATTreq should be set to 1
What does the "sysvarmon" say ?
Message 11 of 32
ATTDIA is set to 1
ATTreq is set to one
sysvarmon says its an unknown command
Message 12 of 32
-FDC-
Sysvarmonitor could be after 2010 (I'm not sure)
Did you try ALT+Tab after the insert command ?
Message 13 of 32
alt + tab is a keyboard shortcut for switching through programs you have open on you desktop...
Message 14 of 32
-FDC-
Sorry, I meant ALT+Spacebar
Message 15 of 32
scottspeig
Does turning dynamic input off work?
Mind you, if you use dynamic input you wouldn't want to do that...
Message 16 of 32
Alt+spacebar doesn't do anything.
Message 17 of 32
turning off dynamic input off just makes it where i have to use the command bar.
Message 18 of 32
scottspeig
Have you tried these keyboard combinations:
Alt+Space bar
M
Hit any of the arrow keys on the keyboard
Move mouse to center of screen and dialog boxes off screen will follow
(This assumes the dialog box is open, just off screen)
I'd try it with a dialog box that is working first so you know what is happening and how it works.
Message 19 of 32
if you look at the screenshot i posted, it gives me prompts instead of a dialog box. the dialog box isn't hidden. if the dialog box was hidden it wouldn't give me the prompts. but i did try it just in case but the results was as i figured. if i am in the command the the prompts on screen it doesn't give me the option to move the window because there is no window to move.
Message 20 of 32
scottspeig
Long shot:
To Display Hidden Messages and Dialog Boxes
Use this method to display all dialog boxes that are marked to not display again or to always use a specified option.
  1. Click Application button Options.
  2. In the Options dialog box, System tab, under General Options, click Hidden Messages Settings.
  3. In the Hidden Message Settings dialog box, select the dialog boxes or messages that should no longer be hidden.
