Snapping to unseen objects with Object Snap turned off
Message 1 of 10
I am running Architecture 2017 and am having an issue in certain drawings where the crosshairs will snap to a random spot as if magnetized to it.
The cursor jumps to random places and it is almost impossible to paste an object where you want it to be and the entire process is slowed down as the cursor progressively snaps from one random place to the next in slow motion.
My object snaps are all turned off and I believe I turned one of the "magnet" settings off as well yet this problem persists.
Thoughts ?
Replies (9)
Message 2 of 10
imadHabash
Hi and Welcome to AutoCAD Forum,
does this issue happend in general or in a certain dwg file? please attache here your dwg or part of ( if possible ) and guide us where to look to check your issue .
regards,
Imad Habash
Message 3 of 10
kadmonkee
go into Options / Drafting tab check your Aperture size and Autosnap Marker size
if you reduce these sizes it may fix some of the issues
are there any 3d objects, elements in the file?
also confirm your Object Snap Options what to ignore and Z axis settings.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 4 of 10
pendean
Community Legend
Community Legend
Do you "freeze" or just "turn off" layers you do not wish to see?
Message 5 of 10
gotphish001
Grid snap on? or do you have your precision set lower than you are trying to snap too?
Nick DiPietro
Cad Manager/Monkey
Message 6 of 10
Snap is off.
Units are in mm which is what we want.
[cid:image001.png@01D353C9.B699A1D0]
Message 7 of 10
This construct has a view file overlayed so there are 995 layers. A few are turned off and a few others are frozen but most layers are on.
Message 8 of 10
OK, did all of that that with no noticeable improvement.
Message 9 of 10
kadmonkee
are there any 3d components in any of the xref files?
anything that might be off axis in any files?
thank you
Message 10 of 10
GrantsPirate
On this page in the upper right is a search function.  Search on CROSSHAIR JUMPING and go through those posts.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
