AutoCAD Forum
DGNEXPORT function incorrect linestyle
3 REPLIES 3
272 Views, 3 Replies
I am trying to export DWG files from Autocad 2021 to DGN files however when I complete the export, the dashed linestyles have all reverted to to solid lines. The settings box shows the the linestyles will convert to an appropriate conversion but doesn't actually do it.
3 REPLIES 3
Patchy
 Microstation can open .dwg, try and see if any better.
in reply to: Patchy
Unfortunately I do not have access to microstation, only my clients company does but my contact is unable to test this.
Patchy
Try ltscale before export to dgn.
This article is mentioning the other way around.
https://communities.bentley.com/products/microstation/w/microstation__wiki/15269/saving-a-dgn-to-dwg...
Forma Design Contest
AutoCAD Beta
