I am after assistance in how to write a program within AutoCAD which will allow me to bring in my custom blocks from drop down menus? I remember something about MNU, MNX and CUI files but this is all beyond me now.
Thanks in advance.
Are you talking about the ribbon or the old menus?
for the ribbon open the CUI.
Create a new command by clicking the star. Give the command a name. Put in the macro for your block in the macro section.
If you want Icons for you block assign them to the command
Next in the panels section right click and select new panel
Name the Panel appropriately. Expand the panel and add you block commands that you created. To do this click and drag your command from the command list into the section of the panel where you want them to show up.
Once you have all the commands for all your block like you want it in the panel, then click and drag your panel to the appropriate tab.
Click Apply in the CUI
Your panel should show up on the ribbon now.
Remember to Save your workspace/customizations.
CADnoob
Thanks for thee quick reply, I really appreciate it.
I am planning to load up different menus for the equipment I will then need menus to cascade down with other sub menus. I am assuming what you are showing here can be modified?
Instead of your menu, look into creating a Tool Palette. These links may provide some insight.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
