AutoCAD Forum
Developing custom drop down menus for blocks?
5 REPLIES 5
idholmes
614 Views, 5 Replies
I am after assistance in how to write a program within AutoCAD which will allow me to bring in my custom blocks from drop down menus?  I remember something about MNU, MNX and CUI files but this is all beyond me now.
Thanks in advance.
5 REPLIES 5
TheCADnoob
in reply to: idholmes
Are you talking about the ribbon or the old menus?
for the ribbon open the CUI.
Create a new command by clicking the star. Give the command a name. Put in the macro for your block in the macro section.
If you want Icons for you block assign them to the command
Next in the panels section right click and select new panel
Name the Panel appropriately. Expand the panel and add you block commands that you created. To do this click and drag your command from the command list into the section of the panel where you want them to show up.
Once you have all the commands for all your block like you want it in the panel, then click and drag your panel to the appropriate tab.
Click Apply in the CUI
Your panel should show up on the ribbon now.
Remember to Save your workspace/customizations.
CADnoob
idholmes
Thanks for thee quick reply, I really appreciate it.
I am planning to load up different menus for the equipment I will then need menus to cascade down with other sub menus.  I am assuming what you are showing here can be modified?
pendean
Greetings @idholmes
May I ask why you wish to do the most difficult time-consuming method in AutoCAD to create pulldowns just for blocks library access, when a simpler tool like the old ADCENTER command (I am assuming you already have these blocks organized in files/folders) or the newer BLOCKS palette let you have that right there too?
TheCADnoob
Right click and you can see some options. I would echo @pendean , this does seem like a lot of work and may not be the best way to approach the problem.
CADnoob
Valentin-WSP
@idholmes ,
Instead of your menu, look into creating a Tool Palette. These links may provide some insight.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Forma Design Contest
