Detail View unable to use
i have a 2d model. i have layouts created. i want to add a detail view i go to view detail and get message unable to preform action this was created with newer version.  this is model was created in 2017 i am usesing 2017...
Vinayv4v
Please go through the discussion and check if it resolves your problem.
https://forums.autodesk.com/t5/autocad-structural-detailing/adding-a-detail-view/td-p/3410193
Cheers,
Vinay Vijayakumaran
imadHabash
I suggest to follow this AKN article and learn how to do it.
Imad Habash
Alfred.NESWADBA
Do you mean that?
...if so then then I have a bit problems understanding you. This command needs a 3D-model and from that with command _VIEWBASE generated view-objects from your 3D-model.
If you mean anything else with "add detail view" then please describe what command you are using to get that done (maybe a screenrecording helps us to understand better what you have, >>>free download here<<<). If you can show us the drawing, it would be great!
Which product exactly (plain AutoCAD or a vertical product based on AutoCAD like AutoCAD Architecture, ...) and which service pack (start command _ABOUT on both system and compare the exact product version).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
Hi @Anonymous,
Was the model created in AutoCAD originally and possibly a different version? If you could attach a sample file for me to look at I will take a look for you and try to offer some solutions for you.
John Vellek
john.vellek
Hi @Anonymous,
I haven't seen an update from you.Can you share a file so I can try to resolve this for you?
John Vellek
