Design question
This widget could not be displayed.
Design question
Dear Sir/ Manam
I want to ask you something .I was watcing a tutorial video and the proffesional draw this drawing
(screenshot1)
when he started to drawing ,he used a polyline to create the drawing
HOW he  understand,that he should use the command :polyline  to start creating the drawing, when he saw the screeshot 1?
Accepted solutions (3)
imadHabash
HI,
since a POLYLINE is a connected sequence of line segments usually when you start to creat 3D objects POLYLINES are the right and proper command for all 3D commands ( Extrude,Presspull,Sweep....etc).
Imad Habash
Alfred.NESWADBA
I guess this could be the answer:
In screenshot 1 you can see this contour that is then revolved to built up the body:
And the red contour seems to be the polyline object from your screenshot 2.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
i want to ask you something else.
1)How did he understand that he must start with this manner the drawing?
2)when did he find the dimension 0.625 in the screenshot i do not see this dimension.?
I had broken my mind to try to find the answer.
Now i undertand with your help how he started the exersice.Thank you,very match for your help.
very difficult exersice for me without your help!!1
Alfred.NESWADBA
Training and/or experience. 😉
There are also other ways to get that done (starting 3D with outer cylinder, inner cylinder, ...), starting with 2D contours is in most cases the easier one.
You can see the
  • outer cylinder with the inner diameter 1,75 ==> radius 0.875
  • inner cylinder with an outer diameter 0.5 ==> radius 0.25
Result is 0.875 - 0.25 = 0.625
. alfred -
Alfred NESWADBA
