Design Center
Design Center
Message 1 of 10
Design Center
My blocks are showing up as black blocks in the Design Center. What do I do to clear this up?
Linda Lawson
Replies (9)
Message 2 of 10
john.vellek
Hi Linda,
When I place all the blocks into a single file (run BLOCKICON) and save them they show up properly in Design Center.  As another step, some users have found that making sure that background color is set to white helps the icons show up properly in Design Center.
Will this work for you? I usually keep all my standard blocks in select files to use as a library so I can group them and manage them easier.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 3 of 10
I am not sure exactly what you do when you run BLOCKICON.
Linda Lawson
Piping Designer | Day & Zimmermann
O 864.241.6706
125 The Parkway, Suite 400 | Greenville, SC 29615
[email protected]
www.dayzim.com
Follow us:
[Twitter][LinkedIn][Facebook][YouTube]
We do what we say.(r)
Message 4 of 10
john.vellek
Hi @Anonymous,
BLOCKICON is the command generates preview images for blocks displayed in DesignCenter.
Simply type it in and select the wildcard (*)
then if you save the drawing you should be able to access it using Design Center with all of the block icons visible.
If you have a sample library file with your blocks in it I would be happy to take a look and maybe make a video for you.
John Vellek
Message 5 of 10
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 6 of 10
This is some of my drawings that I am having trouble with. I resaved them with the white background. But I made a drawing called Test and inserted the above files into the test drawing. Then I typed the BLOCKICON command and hit enter. It said it redefined all blocks. Then I went back to Design Center and found the Test drawing and picked blocks. The 3WAVA01 THRU 3WVA07 are all coming out black icon when viewed in Design Center. The others are good. Why are the 3WAYVA01 THRU 3WVA07 still coming out black?
Linda Lawson
Message 7 of 10
john.vellek
Hi Linda, Is it possible to attach the drawing(s)? I would be happy to take a look at the two offending blocks.
John Vellek
Message 8 of 10
See attached.
Linda Lawson
Message 9 of 10
john.vellek
😞 No attachment 😞
Check to make sure that your firewall is not preventing the file from being uploaded. You might also try putting it in a ZIP file before attaching.
John Vellek
Message 10 of 10
Try this.
Linda Lawson
