Deselecting by Shift+Click Stopped Working?
Message 1 of 25
A while ago I found out you can deselect something from your current selection set by holding down the shift key and clicking on it. This was a pretty useful tool...but then it randomly stopped working today for me. Any ideas as to why this might have happened?
Replies (24)
Message 2 of 25
Alfred.NESWADBA
verify the PICKADD variable, is it set to 2 or another value.
Also interesting might be if you have Map3D or Civil3D, because then you have a command _MAPIOPTIONS and in the dialog ==> 2nd tab you also have a option for how <Shift><Click> works.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 25
Checked the PICKADD variable--it was set to 1 and I changed it to 2, which didn't solve the problem.
I actually am using Civil 3D and I tried pulling up that dialog but I can't find the option you're talking about. What are the texts for the tab and for the option?
Message 4 of 25
rkmcswain
See if one of these is perhaps the problem.
http://cadpanacea.com/node/14
http://cadpanacea.com/node/230
This reply has been edited by the moderation team as the legacy links were no longer valid
R.K. McSwain     | CADpanacea | on twitter
Message 5 of 25
Thanks rkmcswain! It turned out changing things in MAPIOPTIONS (which is different from MAPOPTIONS, which is what I mistakenly read the command Alfred posted as, which explains my previous confusion, BTW) didn't do anything to help, but turning the "Shift+Left click image select" option off in IOPTIONS did the trick for me.
Message 6 of 25
patpat79
It is indeed the IOPTIONS.... well that works for me...
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Message 7 of 25
This worked for me too! Thanks
Message 8 of 25
Worked for me too, with the caveat that the command is now "IOPTIONS" and not "MAPIOPTIONS." Thanks for the help, rkmcswain!
Message 9 of 25
rkmcswain
@Anonymous  - when I type in IOPTIONS, the command line changes it to MAPIOPTIONS, which is still documented.
Message 10 of 25
Alfred.NESWADBA
Do you have RasterDesign installed?
- alfred -
Alfred NESWADBA
Message 11 of 25
this fixed the issue for me in civil3D
thank you!
Message 12 of 25
FilipBednarski
Helped me in 2021 (AutoCAD 2017). Thanks!
Message 13 of 25
cadffm
No rasterdesign installed?
Is it the case also with a simple line object?
https://forums.autodesk.com/t5/autocad-forum/autocad-2015-can-not-shift-click-to-deselect-a-solid-su...
Sebastian
Message 14 of 25
dain.synhorst
Community Visitor
Community Visitor
I have rasterdesign, but I had run both IOPTIONS and MAPIOPTIONS to get this to work. When just doing one or the other commands shift-click-delsect still does not work. In other sense I had unselect Shift+Left Click Image Select in IOPTIONS and MAPIOPTIONS. (Civil 3D 2022)
Message 15 of 25
safavi_maryam
Community Visitor
Community Visitor
Worked for me too
Message 16 of 25
Frank_EganVKZC5
Community Visitor
Community Visitor
I have raster and tried the IOPTIONS and it didn't work.
Message 17 of 25
Amy.taylor
Currently working in AutoCAD 2023, with Raster Design installed. C3D 2023 installed but not open.
IOPTIONS works for me (Raster Design perhaps?), but MAPIOPTIONS does not (Civil 3D perhaps?).
Either way, I'm glad for this post.
Message 18 of 25
jbraddy2
Community Visitor
Community Visitor
deselecting it in "ioptions worked for me" but deselecting it from "mapioptions" did not. Thanks for clerifying the difference!
Message 19 of 25
ThreadRed
I just had the same issue. I found out that I had an image on a turned off layer that's causing issues with deselecting objects.
Message 20 of 25
jchristiansenMAY4G
Thank you for this. I tried the MAPIOPTION and it didn't work. Using just IOPTION, it worked.
