Deleting a Viewport in Paperspace
Hi, I was hoping someone here could help me with a problem I've encountered. I created a viewport in my paperspace and I want to delete the viewport; however, whenever I click outside into the paperspace, there is no command to delete the viewport. I tried deleting it inside the model space, but that just deletes the model, which of course I dont want. How do I go about deleting this viewport? Thank you
cadffm
Viewport line circle, all the same.
Please unlock and thaw all layers.
Command pspace to make sure you are in paperspace
Select the viewport, run erase command or press del key.
If you can not see the viewport,
Deselect AF Freeze for all layers in paperspace
Sebastian
