Select Similar Settings Missing
tammyg
3,038 次查看
2 条回复
1 条消息(共 3 条)
tammyg
I'm working in Autocad Architecture 2018 as an upgrade from 2017 Autocad and I'm used to typing the command SELECTSIMILAR, then SETTINGS to toggle these settings. 2018 doesn't have a settings option through either SELECTSIMILAR OR SELECTSIMILAR MODE OR TYPING SE. I even entered the Select Similar mode by # and it appears select similar just does not work in this version of Autocad. Hellpp
0 个赞
已接受的解答 (1)
3,039 次查看
2 条回复
回复 (2)
2 条消息(共 3 条)
imadHabash
已接受的解答
i suggest to try REDEFINE command for both commands and see if any changes .
Imad Habash
3 条消息(共 3 条)
tammyg
It worked, thank you!
