& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
I can't delete ACAD_PROXY_ENTITY in 2021. I tried using the posted fix using wblock and command line prompt.to convert but neither works. Drawing was drawn in ACAD 2018.
What is the PROXY entity from? Can you install the Object Enabler and do this?
not whole information inside the file was created in (plain) ACAD2018, you/we have to know which program is missing!
Set ProxyNotice to 1, open your file and write down the content of the appearing dialog.
Or share the file, what is much better for us to help you.
rkmswains tip is the best way,
Try it, search and install object enabler for the missing program and then use -ExportToAutoCAD
But wait: You ask about DELETE? And you talk about ACAD_PROXY_ENTITY?
In this case WBLOCK with option Object selection -should work. Select only the objects you want to keep.
Sebastian
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
