STRETCH command
STRETCH command
glomauro
Message 1 of 8
STRETCH command
glomauro
the STRETCH command (the unique and irreplaceable Autocad command) don't work with central click and wheel of the mouse. It seems to lose the window. I think that the last upgrade is for another program. Please reemploy the old
software programmers.
Replies (7)
Message 2 of 8
RobDraw
No need to double post such madness.
Rob
Message 3 of 8
j.palmeL29YX
@glomauro wrote:
the STRETCH command ... don't work with central click and wheel of the mouse. It seems to lose the window.
Please describe your "old" workflow more detailled and tell us what you're missing now.
(And also which AutoCAD version(s) is (are) affected. )
Which "last update" are you talking about?
I see only ???
Jürgen Palme
Message 4 of 8
cadffm
@j.palmeL29YX  schrieb:
1. Please describe your "old" workflow more detailled
2. and tell us what you're missing now.
3. (And also which AutoCAD version(s) is (are) affected. )
4. Which "last update" are you talking about?
I see only ???
Totally agree.
What was your Version "before",
what is your current version you talk about,
which workflow in detail (older version)
which happens in the new Version/after Update
The information about the "new" version, please share the data from Command: ABOUT dialog.
Sebastian
Message 5 of 8
glomauro
not REVIT, but AUTOCAD (revit didn't have the faboulous STRETCH command, sigh!)
Message 6 of 8
RobDraw
Yup, definitely seeing a problem with this one.
Rob
Message 7 of 8
dmfrazier
For some, apparently, even AutoCAD "doesn't always work the way you think it should". 😉
Message 8 of 8
imadHabash
I suggest to make a screencast for your issue . then we can see if it's a real AutoCAD problem that need to solve or not .
Imad Habash
