Currently, when I do an angled dimension, I get a degree symbol with a feet or inch symbol after it.
Does anyone know a way to permanently remove the feet/inch symbol when I do these dimensions? (other than manually removing the suffix in properties for each dimension)
Solved by imadHabash. Go to Solution.
seems like DIMPOST holds that suffix. Call dimpost and pass either . (period) or , (comma) to remove the suffix. For existing dimensions , select similar and change the suffix in properties.
also you can modify it from DDIM command and as mentioned in the previous post.
Imad Habash
The problem with this option is it removes inch/feet from my regular linear dimensions as well. I just want it removed from my angled dimensions
i suggest to make a new dimension style to use it for angled dimensions (without inch / feet ) , just select one of those angled dimensions then right click to choose select similar then move them to the new dimension style.
Imad Habash
What unit format do you have set for linear dimensions? If Architectural, you'll get feet and inches marks without needing to spell out a suffix, so the angular Dimensions won't get the suffix. If you're doing Civil engineering with a foot as a drawing unit, and use decimal units for linear Dimensions, you do need the foot-mark suffix. Unfortunately, even though the dialog box has that in the linear-Dimensions category, it seems to apply it to angular-dimension text, too, which seems like an error in programming. You can get around that by making a separate Dimension Style that you use for angular dimensions, without the suffix.
As suggested in other posts, make a new dimension style. For any existing drawings try below lisp. Very lightly tested
;:Ranjit Singh ;;8/31/17 (defun c:somefunc (/ ent etdata) (and (mapcar '(lambda (x) (and (member '(100 . "AcDb2LineAngularDimension") (setq etdata (entget x))) (setq ent (cdr (assoc -2 (tblsearch "block" (cdr (assoc 2 etdata)))))) (while ent (and (= "MTEXT" (cdr (assoc 0 (setq etdata (entget ent))))) (entmod (subst (cons 1 (vl-string-right-trim "'" (cdr (assoc 1 etdata)))) (assoc 1 etdata) etdata))) (setq ent (entnext ent))))) (mapcar 'cadr (ssnamex (ssget "_x" '((0 . "dimension")))))) (vla-regen (vla-get-activedocument (vlax-get-acad-object)) 1)) (princ))
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
