Default Units
Default Units
Jkane2022
Default Units
Jkane2022
How can I change the default drawing units, so instead of changing from inches to millimeters every time I start a new drawing, it is already in millimeters when I begin? I use metric much more often.
Patchy
Use command -dwgunits after start a new drawing, change it to meter, then save it as acadiso.dwt
Jkane2022
I'd rather be able to save it to acad.dwt because it uses ansi dimensions. But I tried and it didn't have an effect when starting a new drawing
ritzofriya
(SETVAR "INSUNITS" 4)
Jkane2022
This time, it changes the units to millimeters in the one drawing, but if I close and open a new drawing it's back to inches. I want it to be millimeters for every drawing, but I also want to keep ansi dimensions
ritzofriya
What I do means, prepared a program to enable all settings asper my requirement.
example: unit, line weight, ortho, snap, all so once i run the program , it will make ready for my requirements, try that if you feel useful. also i have all my blocks and layers in one group also page setup manager, so for me all will be there in one click.
Valentin_CAD
@Jkane2022 ,
Save your custom drawing template as (*.dwt) and set the path in the OPTIONS "Default Template File Name for QNEW".
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
