default color and material in imported .step files from commercial providers
No aplicable
2.887 Vistas
10 Respuestas
Mensaje 1 de 11
No aplicable
I have imported .step files from commercial providers (eg. Thorlabs.com) to assemble a microscope in AutoCAD2015. All parts have lost their assigned color and material and appear in as uniform default gray color. I am not able to change their appearance either by block or by layer.
Is there a way to import third person .step files without losing their color and material (eg blocks that contain glass and anodized metal)?
Is there a way to change the color or material of blocks that have been imported from third party websites?
To reproduce my problem, for example import this step file:
https://www.thorlabs.com/_sd.cfm?fileName=6820-E0W.step&partNumber=KM100-E02
and look at it with realistic view. Ideally you would see the reflective surface of the mirror and anodized and reflective parts of metal like shown in this pdf:
https://www.thorlabs.com/drawings/118d8b30e740e9d4-95AA7AF8-0E46-926E-ABBA42407071181A/KM100-E02-Aut...
Does anyone know what to do?
thanks a lot!
Caroline
0 Me gusta
Soluciones aceptadas (2)
2.888 Vistas
10 Respuestas
Respuestas (10)
Mensaje 2 de 11
Alfred.NESWADBA
>> I have imported .step files [...] All parts have lost their assigned color and material
The STEP files don't have a material or color defined, you can look into it using a simple ascii-editor.
So you need to reassign this information in whatever system you import these files.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
0 Me gusta
Mensaje 3 de 11
john.vellek
Hi @Anonymous,
@Alfred.NESWADBAjust beat me to this. I opened your STEP file in Notepad and did a search for Material but it didn't find it in the file.
John Vellek
Mensaje 4 de 11
Alfred.NESWADBA
Solución aceptada
... whereas colors are here 😉
- alfred -
Alfred NESWADBA
Mensaje 5 de 11
No aplicable
this looks great indeed but how did you get AutoCAD to display it? I am happy to just have the colours and not the material but for me everything looks uniformly gray. The only way i can reach this look you posted is by exploding the block I imported and clicking on each individual bit to assign it a material. Obviously a tedious task and if there was a way to visualise the predefined colours I could save much time.
0 Me gusta
Mensaje 6 de 11
Alfred.NESWADBA
I imported the STEP file and changed the visual style to "Realistic". 😉
Which version of AutoCAD do you use?
- alfred -
Alfred NESWADBA
0 Me gusta
Mensaje 7 de 11
No aplicable
Hi alfred,
thanks for your replies and your patience.
I do the exact same thing: under. insert>> import I select my step file and
then I look at it under realistic visual style. For me it looks like in the
attached screenshot.
Any idea what is causing me to not see colours set in the step file?
thanks for your help, much appreciated!
Caroline
0 Me gusta
Mensaje 8 de 11
No aplicable
sorry, I am using AutoCAD 2015 it says product version J.141.0.0
0 Me gusta
Mensaje 9 de 11
Alfred.NESWADBA
>> For me it looks like in the attached screenshot.
Sorry, no attachment arrived here.
Please note that answers using your mail system does not forward attachments, to attach files start your internet browser and us the reply button in that forum/that thread. Then you can attach files.
Again my question: which version of AutoCAD are you using?
- alfred -
Alfred NESWADBA
0 Me gusta
Mensaje 10 de 11
Alfred.NESWADBA
Solución aceptada
sorry, posts crossed.
Yep, that (old) release does not import colors, I tried now again ... and AutoCAD 2016 seems to be the first recognizing the colors in the STEP file.
I have attached the drawing with colors here (be careful because of the units, I'm not sure if the size of the object matches the units setting).
As you are student you can download and install the newest version of AutoCAD, so in case you need that more often, that's the way to go 😉
- alfred -
Alfred NESWADBA
Mensaje 11 de 11
No aplicable
Great thank you, that's clarity in the end!
Thanks a lot!
0 Me gusta
